Important
If you do not configure the thresholds, EDM displays only the ingress and egress records that are currently in use.
- In the navigation pane, expand the following folders: .
 - Click IPv6 Mroute.
 - Click the Resource Usage tab.
 - Configure the ingress and egress thresholds.
 - Configure the notification methods.
 - Click Apply.
Resource Usage field descriptions
Use the data in the following table to use the Resource Usage tab.
 Name  |
 Description  |
 Ingress Records In-Use  |
 Displays the number of ingress records (source or group) traversing the switch.  |
 Egress Records In-Use  |
 Displays the number of egress records traversing the switch.  |
 Ingress Threshold  |
 Configures the ingress threshold level (0–32767).  |
 Egress Threshold  |
 Configures the egress threshold level (0–32767).  |
 SendTrapAndLog  |
 Sends both trap and log notification messages after the number of streams exceeds a threshold level.  |
 SendTrapOnly  |
 Sends only trap notification messages after the number of streams exceeds a threshold level. You can configure only one notification type.  |
 LogMsgOnly  |
 Sends only log notification messages after the number of streams exceeds a threshold level.  |
