Configure OVSDB Globally
Use the following procedure to configure the OVSDB certificates, private key, and replication global settings.
- Select OVSDB.
- Select the Globals tab.
- Select Enable.
- In CertificateFilename, type the filepath/filename.
- In CertFileInstallAction, select install.
- Select Apply.
- In PrivateKeyFilename, type the filepath/filename.
- In PrivateKeyInstallAction, select install.
- Select Apply.
- Select ReplicationEnable.
- In ReplicationPeerIpAddr, type the IP address.
- In ReplicationLocalIpAddr, type the IP address.
- Select Apply.
- Verify the ReplicationState.
Globals field descriptions
Use the data in the following table to use the Globals tab.
Name |
Description |
Enable |
Enables or disables the feature. Default is disabled (cleared). |
CertificateFilename |
Specifies the filename of the certificate. |
CertFileInstallAction |
Specifies to install or uninstall the certificate. You must have a certificate file on the switch. |
PrivateKeyFilename |
Specifies the filename of the private key. |
PrivateKeyInstallAction |
Specifies to install or uninstall the private key. You must have a private key file on the switch. |
ReplicationEnable |
Enables or disables replication support. Default is disabled (cleared). |
ReplicationPeerIpAddr |
Specifies the replication server peer IP address in A.B.C.D format. |
ReplicationLocalIpAddr |
Specifies the replication local IP address in A.B.C.D format. |
ReplicationState |
Displays the current replication status. |
