Use the following procedure to configure optional SPBM parameters.
Switch> enable
Switch# configure terminal
Switch(config)# spbm ethertype 0x8100
Switch(config-isis)# no router isis enable
Switch(config)# router isis
Switch(config-isis)# spbm 1 lsdb-trap enable
Switch(config-isis)# router isis enable
Switch(config-isis)# exit
Switch(config)# interface gigabitethernet 1/7
Switch(config-if)# no isis enable
Switch(config-if)# isis spbm 1 interface-type pt-pt
Switch(config-if)# isis spbm 1 l1–metric 500
Switch(config-if)# isis enable
The following table defines parameters for the spbm command.
 Variable  |
 Value  |
 ethertype {0x8100 | 0x88a8}  |
 Configures the SPBM ethertype. The default value is 0x8100.  |
 <1–100> lsdb-trap enable  |
 Configures whether to enable or disable a trap when the SPBM LSDB changes. The default is disabled. Use the no or default options to disable LSDB traps.  |
The following table defines parameters for the isis spbm command.
 Variable  |
 Value  |
 <1–100> interface-type {broadcast|pt-pt}  |
 Configures the SPBM instance interface-type on the IS-IS interface located on the specified port or MLT. SPBM only supports the point-to-point (pt-pt) interface type. The default is pt-pt. Use the no or default options to set this parameter to the default value of pt-pt.  |
 <1–100> l1–metric {<1–16777215> | auto}  |
 Configures the IS-IS interface level 1 metric on the specified port or MLT. The default value is 10. Use the no or default options to set this parameter to the default. Use auto and the network route is determined by summing the lowest value metrics. The metrics are inversely proportional to port speed.  |
