View Traceroute Results
View traceroute results to view performance-related data.
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
 - Click Ping/Trace Route.
 - Click the Trace Route Control tab.
 - Select a traceroute entry.
 - Click Trace Route Result.
Trace Route Result Field Descriptions
Use the data in the following table to use the Trace Route Result tab.
 Name  |
 Description  |
 OwnerIndex  |
 Specifies the index of the owner.  |
 TestName  |
 Specifies the name of the test.  |
 OperStatus  |
 Specifies the operational status of the test. The default is disabled.  |
 CurHopCount  |
 Specifies the current count of hops.  |
 CurProbeCount  |
 Specifies the current count of probes.  |
 IpTgtAddressType  |
 Specifies the IP target address type  |
 IpTgtAddr  |
 Specifies the IP target address.  |
 TestAttempts  |
 Specifies the number of test attempts.  |
 TestSuccesses  |
 Specifies the number of successful test attempts.  |
 LastGoodPath  |
 Specifies the date and time when the last response is received for a probe.  |
