Perform this procedure to enable and manage the web server using the Command Line Interface (CLI). After you enable the web server, you can connect to EDM.
HTTP and FTP support both IPv4 and IPv6 addresses, with no difference in functionality or configuration. The TFTP server supports both IPv4 and IPv6 addresses. The TFTP client is not supported, only the server.
This procedure assumes that you use the default port assignments. You can change the port number used for HTTP and HTTPS.
Important
To enable HTTP access to the device, you must disable the web server secure-only option. To enable HTTPS access to the device, the web server secure-only option is enabled by default.
Switch:1(config)#show web-server
Web Server Info :
        Status                    : off
        Secure-only               : enabled
        TLS-minimum-version       : tlsv12
        RO Username Status        : disabled
        RO Username               : user
        RO Password               : ********
        RWA Username              : admin
        RWA Password              : ********
        Def-display-rows          : 30
        Inactivity timeout        : 900 sec
        Html help tftp source-dir :
        HttpPort                  : 80
        HttpsPort                 : 443
        NumHits                   : 0
        NumAccessChecks           : 0
        NumAccessBlocks           : 0
        NumRxErrors               : 0
        NumTxErrors               : 0
        NumSetRequest             : 0
        Minimum password length   : 8
        Last Host Access Blocked  : 0.0.0.0
        In use certificate        : Self signed
        Certificate Truspoint CA Name :
        Certificate with Subject Name : 823
        Ciphers-Tls               : TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
                                    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
                                    TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 TLS_DHE_RSA_WITH_AES_256_CBC_SHA
                                    TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 TLS_DHE_RSA_WITH_AES_128_CBC_SHA
                                    TLS_RSA_WITH_AES_256_CBC_SHA256 TLS_RSA_WITH_AES_256_CBC_SHA
                                    TLS_RSA_WITH_AES_128_CBC_SHA256 TLS_RSA_WITH_AES_128_CBC_SHA
        SSL renegotiation         : enabled
Use the data in the following table to use the web-server command.
 Variable  |
 Value  |
 def-display-rows <10-100>  |
 Configures the number of rows each page displays, between 10 and 100.  |
 enable  |
 Enables the web interface. To disable the web server, use the no form of this command: no web-server [enable]  |
 help-tftp <WORD/0-256>  |
 Configures the TFTP or FTP directory for Help files, in one of the following formats: a.b.c.d:/| peer:/ [<dir>]. The path can use 0–256 characters. The following example paths illustrate the correct format:
 http-port <80-49151>  |
 Configures the web server HTTP port. The default port is 80.  |
 https-port <443-49151>  |
 Configure the web server HTTPS port. The default port is 443.  |
 inactivity-timeout<30–65535>  |
 Configures the web-server session inactivity timeout. The default is 900 seconds (15 minutes).  |
 password {ro | rwa} WORD<1-20>  |
 Configures the logon and password for the web interface.  |
 password min-passwd-len<1–32>  |
 Configures the minimum password length. By default, the minimum password length is 8 characters.  |
 read-only-user  |
 Enables read-only user for the web server.  |
 secure-only  |
 Enables secure-only access for the web server.  |
| ssl-renegotiation |
               Enables SSL renegotiation in the web server. To disable SSL renegotiation, use the no form of this command: no web-server ssl-renegotiation The default is enabled.  |
 tls-min-ver<tlsv10|tlsv11|tlsv12>  |
 Configures the minimum version of the TLS protocol supported by the web-server. You can select among the following:
 The default is tlsv12.  |
