Perform this procedure to view information about the operating status of the power supplies.
- Select Power Supply.
- Select the Detail tab.
Detail Field Descriptions
Use the data in the following table to use the Detail tab.
Name |
Description |
Type |
Describes the type of power used. Note: To know what
power types the switch supports, see the hardware installation
documentation.
Description |
Provides a description of the power supply. |
SerialNumber |
Specifies the power supply serial number. |
HardwareRevision |
Specifies the hardware revision number. |
PartNumber |
Specifies the power supply part number. |
PowerSupplyOperStatus |
Specifies the status of the power supply as one of the following:
InputLineVoltage |
Displays the input line voltage:
OutputWatts |
Displays the output power of this power supply. |
