View IPv6 Default Routers
View the table of default routers learned from router advertisement messages.
A maximum of four routers are visible in the default routers list.
  1. In the navigation tree, expand Configuration > IPv6.
  2. Select IPv6.
  3. Select the Default Routers tab.
Default Routers field descriptions
Use the data in the following table to use the Default Routers tab.
Name
Description
Address
Specifies the learned router address for an IPv6 default routers entry.
IfIndex
Specifies the interface number for an IPv6 default routers entry.
Lifetime
Specifies the remaining router lifetime.
Active
Specifies if the default router is active for an IPv6 default routers entry.
