vIST creates a virtualized channel through the SPBM cloud, and this channel connects two SMLT devices to form a virtualized Switch Cluster. Note that the SPBM cloud can consist of as few as two nodes.
Important
When you create a vIST, VLANs assigned to SMLT ports must have an I-SID assigned.
If you assign a VLAN to an I-SID on one SMLT-BEB node, then you must create the same VLAN and assign it to the same I-SID on the peer SMLT-BEB node even if no devices are connected to this second node.
The vIST VLAN must also be associated with an I-SID. You can use the same vIST VLAN in another part of your network, but the I-SID associated with the vIST VLAN must not be used anywhere else.
Simplified Virtual-IST (vIST) is for non-SPB customers who use SMLT with legacy IST. Simplified VIST is available only for legacy multicast deployments when the boot configuration flag (spbm-config-mode) is disabled.
Enable SPBM and IS-IS globally.
Configure SPBM and IS-IS.
Configure a Layer 2 VSN by assigning an I-SID to the C-VLAN, which is used by the vIST.
Important
Do not change the system MTU to less than the default value of 1950 bytes. The system MTU must be 1950 or jumbo because of the header size increase when transmitting packets over the SPBM cloud.
 - Select the Virtual IST tab.
 - In the PeerIp field, type the peer IP address.
 - In the VlanId field, enter a VLAN ID.
 - Select Apply.
Virtual IST field descriptions
Use the data in the following table to help you configure the Virtual IST tab.
 Name  |
 Description  |
 SessionStatus  |
 Displays the status of the vIST session.  |
 PeerIp  |
 Specifies the peer IP address, which is the IP address of the vIST VLAN on the other aggregation switch.  |
 VlanId  |
 Configures a vIST VLAN ID number.  |
