Use this procedure to configure the RADIUS server reachability settings.
Configure values for RADIUS server reachability:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z.
Configure the RADIUS keep-alive timer:
Switch:1(config)#radius reachability keep-alive-timer 30
Configure the RADIUS reachability mode:
Switch:1(config)#radius reachability mode status-server
Configure the RADIUS reachability unreachable timer:
Switch:1(config)#radius reachability unreachable-timer 30
The following table defines parameters for the radius reachability command.
 Variable  |
 Value  |
 keep-alive-timer <30-600>  |
 Specifies, in seconds, the interval between checks when radius server is reachable. The default is 180 seconds.  |
 mode <status-server | use-radius>  |
 Specifies status-server mode or use-radius mode. Status-server mode provides a standard-compliant method for RADIUS reachability. Use-radius mode requires the configuration of dummy packets that are sent to RADIUS servers. The default is use-radius mode.  |
 password WORD<1-16>  |
 Configures the RADIUS request password. The default is extremenetworks.  |
 unreachable-timer <30-600>  |
 Specifies, in seconds, the interval between checks when radius server is unreachable. The default is 60 seconds.  |
 username WORD<1-16>  |
 Configures the RADIUS request username. The default is extremenetworks.  |
