Configure the run-time environment to define generic configuration settings for CLI sessions.
Switch:1>enable Switch:#configure terminal
Use the default option to enable use of the default logon string:
Switch:(config)#default login-message
Use the default option before this parameter to enable use of the default string:
Switch:(config)#default passwordprompt
Configure the allowable number of inbound Telnet sessions:
Switch:(config)#telnet-access sessions 8
Configure the timeout value, in seconds, to wait for a Telnet or CLI login session before terminating the connection:
Switch:(config)#cli timeout 900
Configure the number of lines in the output display for the current session:
Switch:(config)#terminal length 30
Configure scrolling for the output display:
Switch:(config)#terminal more disable
The following table defines parameters for the login-message command.
                                 Variable  |
                                 Value  |
                                 WORD<1-1513>  |
                                 Changes the CLI logon prompt.  |
The following table defines parameters for the passwordprompt command.
                                 Variable  |
                                 Value  |
                                 WORD<1-1510>  |
                                 Changes the CLI password prompt.  |
The following table defines parameters for the telnet-access sessions command.
                                 Variable  |
                                 Value  |
                                 <0-8>  |
                                 Configures the allowable number of inbound Telnet sessions. The default value is 8.  |
The following table defines parameters for the cli time-out command.
                                 Variable  |
                                 Value  |
                                 <30-65535>  |
                                 Configures the timeout value, in seconds, to wait for a Telnet or CLI login session before terminating the connection.  |
The following table defines parameters for the terminal command.
                                 Variable  |
                                 Value  |
                                 <8–64>  |
                                 Configures the number of lines in the output display for the current session. The default is value 23.  |
                                 disable|enable  |
                                 Configures scrolling for the output display. The default is enabled.  |
