View virtual neighbors to view the area and virtual link configuration for the neighboring device.
Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
 - Click OSPF.
 - Click the Virtual Neighbors tab.
Virtual Neighbors field descriptions
Use the data in the following table to use the Virtual Neighbors tab.
 Name  |
 Description  |
 Area  |
 Specifies the sub-network in which the virtual neighbor resides.  |
 RtrId  |
 Specifies the 32-bit integer (represented as an IP address) that uniquely identifies the neighbor router in the autonomous system.  |
 IP Address  |
 Specifies the IP address of the virtual neighboring router.  |
 Options  |
 Specifies the bit mask that corresponds to the neighbor options parameter.  |
 State  |
 Specifies the OSPF interface state.  |
 Events  |
 Specifies the number of state changes or error events that occurred between the OSPF router and the neighbor router.  |
 LsRetransQLen  |
 Specifies the number of elapsed seconds between advertising retransmissions of the same packet to a neighbor.  |
 HelloSuppressed  |
 Specifies whether hello packets from the neighbor are suppressed.  |
                                 RestartHelperStatus  |
                                 Specifies whether the router is acting as a graceful restart helper for the neighbor.  |
                                 RestartHelperAge  |
                                 Specifies the remaining time in the current OSPF graceful restart interval, if the router is acting as a restart helper for the neighbor.  |
                                 RestartHelperExitReason  |
                                 Specifies the outcome of the last attempt at acting as a graceful restart helper for the neighbor.  |
