Use the following procedure to configure MSTP multiple spanning tree instance (MSTI) options.
Configure MSTP MSTI:
Switch:1(config)# spanning-tree mstp msti 62 priority 4096
Use the data in the following table to use the spanning-tree mstp msti <1-63> priority <0–65535> command.
                             Variable  |
                             Value  |
                             <1-63>  |
                             Specifies the instance ID.  |
                             <0–65535>  |
                             Specifies the priority value. Enter values in increments of 4096:
