Configure DHCP Server Global Settings
- In the navigation pane, select .
- Select the Global tab.
- Leave the Enabled check box unselected.
- In the HA Role field, select the role that you want to apply to this switch.
- In the HA Peer Ip field, enter the IPv4 address of the peer switch.
- In the Lease Duration field, enter the default lease expiration timer in seconds.
- In the TFTP Server Ip field, enter the IPv4 address of the default TFTP server that you want DHCP Server to use.
- In the TFTP Server Name field, enter the server name for the TFTP sever.
- In the TFTP Bootfile Name field, enter the boot image file name.
- Select the Authoritative check box if you want to assign this server as an authoritative server.
- In the NetBios Type field, select the option that matches the node type.
- In the NetBios Server Ip, enter the IPv4 address of the NetBIOS server.
- Select Apply.
Global Field Descriptions
Use the data in the following table to configure the Global tab for DHCP Server.
| Name | Description |
| Enabled |
Specifies that the DHCP Server is enabled on the switch. By default, DHCP Server is disabled. |
| HA Role |
Specifies the role of this switch in a DHCP Server High Availability (HA) pairing. In an HA pair, one server must be primary and the other must be secondary. Select one of the following options:
| HA Peer Ip | The IP address of the peer switch in the High Availability pair. |
| Lease Duration | The global lease duration timer, in seconds. |
| TFTP Server Ip | The IPv4 address of the TFTP server that you want to assign to DHCP Server. |
| TFTP Server Name | The server name of the TFTP server that you want to assign to DHCP Server. |
| TFTP Bootfile Name | The file name of the TFTP boot image that you want to assign to clients that connect to DHCP Server. |
| Authoritative | Check this check box to assign this DHCP Server as authoritative. The default setting is non-authoritative. |
| NetBios Type |
Specifies the global NetBios node type. Check the check box that corresponds to the node type:
| Net Bios Server Ip | Specifies the IPv4 address of the global NetBios server. |
