Use this procedure to view FA interface configuration.
The following example displays sample outputs for the show fa interface command.
Switch:1>show fa interface
                            Fabric Attach Interfaces
INTERFACE    SERVER   MGMT     MGMT     MSG AUTH MSG AUTH  TCN   ORIGIN
             STATUS   ISID     CVID     STATUS   KEY
Port 1/1    enabled  0        0        enabled  ****
Port1/10    enabled  0        0        enabled  ****
Port1/6     enabled  0        0        enabled  ****
Port1/11    enabled  0        0        enabled  ****
Mlt2        enabled  0        0        enabled  ****
 5 out of 5 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the port 1/6.
Switch:1>show fa interface port 1/6
 1 out of 4 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the MLT 2.
Switch:1>show fa interface mlt 2
Variable definitions
The following table defines parameters for the show fa interface port command.
 Variable  |
 Value  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
The following table defines parameters for the show fa interface mlt command.
 Variable  |
 Value  |
 <1–512>  |
 The valid range for MLT ID.  |
