Feature |
Product |
Release introduced |
ExtremeCloud IQ Agent |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
Fabric Engine 8.10 |
7720 Series |
VSP 4900 Series |
VOSS 8.2
VOSS 8.2.5
VSP 7400 Series |
VOSS 8.2 |
| Unified Metrics and Events Reporting |
5320 Series |
Fabric Engine 8.8 |
5420 Series |
Fabric Engine 8.8 |
5520 Series |
Fabric Engine 8.8 |
5720 Series |
Fabric Engine 8.8 |
7520 Series |
7720 Series |
VSP 4900 Series |
Not Supported |
VSP 7400 Series |
Not Supported |
For the most current information on switches supported by ExtremeCloud™ IQ, see ExtremeCloud™ IQ Learning What‘s New.
ExtremeCloud IQ provides cloud-managed networking, and delivers unified, full-stack management of wireless access points, switches, and routers. It enables onboarding, configuration, monitoring, troubleshooting, reporting, and more. Using innovative machine learning and artificial intelligence technologies, ExtremeCloud IQ analyzes and interprets millions of network and user data points, from the network edge to the data center, to power actionable business and IT insights, and to deliver new levels of network automation and intelligence.
The switch supports a zero touch connection to ExtremeCloud IQ. Zero touch deployment is used to deploy and configure a switch using ExtremeCloud IQ.
The switch integrates with ExtremeCloud IQ using ExtremeCloud IQ Agent. When you enable IQAgent, you can configure and monitor your devices using ExtremeCloud IQ.
For more information about ExtremeCloud IQ, see https://www.extremenetworks.com/support/documentation/extremecloud-iq/.
