Use this task to configure IPv4 static routes for Management Instances.
For the Management Instance CLIP, you do not need to configure a default or static route. This interface type uses all routing information learned by protocols attached to the VRF. For more information about how to associate a VRF with the CLIP interface, see Configure a Segmented Management Instance.
For the Management Instance OOB and VLAN, you must configure a default or static route to reach the next-hop gateway; no routing protocol information is used to access off-link networks.
You can configure up to 100 IPv4 and IPv6 static routes.
 - Expand Mgmt Instance.
 - Select Mgmt.
 - Select the IpStaticRoute tab.
 - Select Insert.
 - For the Instance, select the type of Management Instance interface.
 - Type the destination IP address and mask.
 - Type the next hop IP address.
 - Optional: Type a metric value.
 - Select Insert.
IpStaticRoute Field Descriptions
Use the data in the following table to use the IpStaticRoute tab.
 Name  |
 Description  |
 Instance  |
 Specifies the Management Instance.  |
 DestAddr  |
 Specifies the destination IP address.  |
 DestMask  |
 Specifies the destination mask.  |
 NextHop  |
 Specifies the next hop address for the static route. Use an IP address in the same subnet as the management VLAN IP address.  |
 IntfName  |
 Specifies the Management Instance interface name for the route entry.  |
 Metric  |
 Specifies the static route cost. The default is 200. The management CLIP uses an internal static route with a weight of 100. If you use both CLIP and VLAN and need to force all default traffic out the management VLAN interface, configure a default static route with a weight lower than 100.  |
 State  |
 Shows if the route is active or inactive.  |
