Unable to Log On Using SSH
If you cannot log on using Secure Shell (SSH), perform the following steps.
Switch:1>enable
Switch:1#show ssh global
Total Active Sessions  : 0
        version            : v2only
        port               : 22
        max-sessions       : 4
        timeout            : 60
        action rsa-keygen  : rsa-keysize 2048
        action dsa-keygen  : dsa-keysize 2048
        rsa-auth           : true
        dsa-auth           : true
        pass-auth          : false
        enable             : true
Job Aid
The following table describes the fields in the output for the show ssh global command.
 Parameter  |
 Description  |
 Total active sessions  |
 Specifies the number of active SSH sessions underway.  |
 version  |
                                 Specifies if SSH is version 1 or version 2. The default is v2. As a best practice, configure the version to v2 only.  |
 port  |
 Specifies the SSH connection port. The default is 22. You cannot configure the following TCP ports as SSH connection ports: 0 to 1024 (except port 22), 1100, 4095, 5000, 5111, 6000, or 999.  |
 max-sessions  |
 Specifies the maximum number of SSH sessions allowed. The default is 4.  |
 timeout  |
 Specifies the SSH connection authentication timeout in seconds. The default is 60 seconds.  |
 action rsa-keygen  |
 Specifies the SSH RSA key size.  |
 action dsa-keygen  |
 Specifies the SSH DSA key size.  |
 rsa-auth  |
 Specifies if RSA authentication is enabled or disabled. The default is enabled.  |
 dsa-auth  |
 Specifies if DSA authentication is enabled or disabled. The default is enabled.  |
 pass-auth  |
 Specifies if password authentication is enabled or disabled. The default is enabled.  |
 enable  |
 Specifies if SSH secure mode is enabled. False is disabled. Secure is enabled.  |
