Use this procedure to view port EAPoL operation statistics.
Use the clear-stats command to clear EAP/NEAP statistics.
Switch:1(config)#show eapol status interface
                         Eap Oper Status
PORT  MAC               STATE         VLAN  PRI  Flex-UNI  I-SID   VLAN:I-SID
NUM                                   ID         Enable    SOURCE  AUTH
1/1  18:a9:05:b1:04:ce  authenticated 10    2    true      radius  0:1015
Total Number of EAP Sessions: 1
            Switch:1(config-if)#show eapol status interface gigabitEthernet 2/1,2/2 verbose
                                                     Eap Oper Status Verbose
PORT  MAC                PAE               VLAN  PRI  Flex-UNI  I-SID        VLAN:I-SID    ACL  ACEs
NUM                      STATUS            ID         Enable    SOURCE
2/1   00:00:02:eb:34:e9  authenticated     N/A   0    true      radius       111:10111     2    2,3
2/1   00:00:02:eb:34:eb  authenticated     N/A   0    true      radius       111:10111     2    1
2/1   00:00:02:eb:34:ed  authenticated     333   0    true      n/a                        2    4
2/1   00:00:02:eb:34:ef  authenticated     444   0    true      n/a                        2    5
2/2   00:00:00:06:a9:df  authenticated     11    0    true      n/a                        1    1
2/2   00:00:00:06:a9:e1  authenticated     N/A   0    true      radius       111:10111
2/2   00:00:00:06:a9:e3  authenticated     33    0    true      n/a                        1    2
2/2   00:00:00:06:a9:e5  authenticated     44    0    true      n/a                        1    3
Total Number of EAP sessions : 8
Use the data in the following table to use the show eapol status command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| <1-4059> | Specifies the VLAN ID for which to show the statistics. |
| verbose | Displays detailed statistics information. |
