Configure Global NTP
Use this procedure to configure the DHCP Server Global NTP tab in
EDM.
- In the navigation pane, select .
- Select the Global NTP tab.
- In the IP Address field, enter the IPv4 address of the NTP server.
- Select Insert.
- Repeat these steps if you want to add additional servers.
Global NTP Field Descriptions
Use the data in the following table to configure the Global NTP tab for DHCP Server.
| Name | Description |
| IP Address | Specifies the IPv4 address of the NTP server. You can enter a maximum of eight DNS servers. |
