Use this procedure to enable IP multicast route statistics.
When you enable or clear IP multicast route statistics on the Controller node of a DvR domain, the configuration is automatically pushed to the Leaf nodes within the domain.
- In the navigation pane, expand the following folders:
 - Click Multicast.
 - Click the Globals tab.
 - In the StatsEnabled field, select the option to enable or disable the collection of statistics.
 - Optional: To clear the statistics, click StatsClear.
 - Click Apply.
Globals Field Definitions
Use the data in the following table to use the Globals tab.
 Field  |
 Description  |
 StatsEnabled  |
 Displays whether the multicast route statistics is enabled.  |
 StatsClear  |
 Clears the multicast route statistics.  |
