The implementation of ACL filters is similar in all switches but there are some differences as summarized in the following tables.
The InVSN Filter shares the port-based groups in the following table.
                             VSP 4900 Series  |
                             VSP 7400 Series  |
                             If you enable Application Telemetry, IPv6 security filter commands and configurations are blocked and not available.  |
                             If you enable Application Telemetry, IPv6 security filter commands and configurations are supported.  |
                             All switches use a filter group as memory to store filter rules. The number of filter groups used can differ:  |
                             The switch supports two ingress filter groups, where each group is shared by two filter types:
                             The switch supports two ingress filter groups, where each type can hold both Security and QoS actions in both Primary Bank and Secondary Bank ranges.  |
                             For each ingress packet, a parallel search is performed on each of the two filter groups.  |
                             Filter  |
                             VSP 4900 Series  |
                             VSP 7400 Series  |
                             Can match both port-based and VLAN-based ACL/ACE  |
                             inVSN ACLs have highest precedence, followed by inPort ACLs. inVLAN ACLs have the lowest priority. If the matching ACEs are of the same type (Primary or Secondary), the ACE action applied is based on the precedence.  |
                             Port-based ACLs have precedence over VLAN-based ACLs. If the matching ACEs are of the same type (Primary or Secondary), then the VLAN-based ACL/ACE is ignored.  |
                             Filter  |
                             VSP 4900 Series  |
                             VSP 7400 Series  |
                             ACE ID ranges supported  |
                             IPv4 filters: Security ACEs: 1–1000 QoS ACEs: 1001–2000 IPv6 filters: ACEs: 1–2000 support both Security and QoS actions  |
                             IPv4 filters support both Security and QoS actions in both Primary Bank and Secondary Bank ranges: Primary Bank: 1-1000 Secondary Bank: 1001-2000 IPv6 filters: ACEs: 1–2000 support both Security and QoS actions  |
                             redirect-next-hop support  |
                             Supported in both the Global Routing Table and VRF contexts.  |
                             VSP 4900 Series  |
                             VSP 7400 Series  |
                             Configuring an ACE with the ARP operation qualifier is supported for OutPort ACLs.  |
                             Configuring an ACE with the ARP operation qualifier is not supported for OutPort ACLs.  |
                             VSP 4900 Series  |
                             VSP 7400 Series  |
                             Supports viewing ACL statistics by the ACE type Security and QoS.  |
                             Supports viewing ACL statistics by the ACE type Primary Bank and Secondary Bank.  |
For QoS scaling and filter scaling information, see VOSS Release Notes.
