Enable IS-IS globally.
Perform this procedure to configure a global IS-IS authentication key for ports that are operating in Auto-sense mode.
If the IS-IS authentication keys on auto-sense ports between two switches do not match, then the auto-sense port state will be auto-sense UNI onboarding, until the keys are matching, then an IS-IS adjacency will be established.Procedure
Configuring simple authentication for IS-IS hello packets on Auto-sense ports:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense isis hello-auth type simple key Secure
The following table defines parameters for the auto-sense isis hello-auth type command.
                                 Variable  |
                                 Value  |
                                 {none|simple|hmac-md5|hmac-sha-256}  |
                                 Specifies the authentication type for IS-IS hello packets on Auto-sense ports:
 The default authentication type is none.  |
                                 key WORD<1-16>  |
                                 Specifies the authentication key (password) used by the receiving router to verify the packet.  |
                                 key-id <1-255>  |
                                 Specifies the key ID.  |
