Use this procedure to configure a client to allow processing of dynamic session changes.
You must enable EAPOL globally and at the port level.
You must enable RADIUS dynamic extensions commands processing at the port level.
 - Click RADIUS CoA.
 - Click Global.
 - Click Insert.
 - In the Address field type a client address.
 - Optional: In the UdpPort field, type a value for client port.
 - Optional: In the Secret field, type a value for the secret key.
 - Select the Enable checkbox to enable dynamic session processing for the client.
 - Click Insert.
Global field descriptions
Use the data in the following table to use the Global tab.
 Name  |
 Description  |
 AddressType  |
 Specifies the type of address contained in the corresponding instance of a RADIUS Dynamic Authorization Client configured in this entry.  |
 Address  |
 Specifies the internet address of a RADIUS Dynamic Authorization Client configured in this entry.  |
 UdpPort  |
 Specifies the UDP port number the server/NAS listens on for requests from the RADIUS Dynamic Authorization Client configured in this entry.  |
 Secret  |
 Specifies the secret key shared between the RADIUS Dynamic Authorization Client and Server. Note that when this object is retrieved, it's value will always by a zero-length octet string.  |
 Enable  |
 Enable processing of dynamic session changes.  |
