Use the following procedure to display the currently running VXLAN configuration.
  1. Enter Privileged EXEC mode:
    enable
  2. Display the running configuration:
    show running-config module vxlan
This example shows the VXLAN information only; it does not show the hardware-specific information that the system also displays in the output for this command. The example shows the VXLAN Gateway in Base Interworking Mode. It also shows an external loopback (see c-vid commands), which enables communication between the VNID and an I-SID in an SPB network.
Switch:1# show running-config module vxlan
# VTEP CONFIGURATION
vtep source-ip 1.1.1.1 vrf underlay-vxlan
# REMOTE VTEP CONFIGURATIONS
vtep 2 ip 1.1.1.1 name "vtep-2"
vtep 67 ip 1.1.1.67 name "vtep-67"
# VNID CONFIGURATION
vnid 12002105 i-sid 102105
c-vid 105 port 1/11
c-vid 2105 port 1/10
vtep 67
exit
