Perform this procedure to specify serial port communication settings. The serial port on the device is the console port.
- In the Device Physical View tab, select the console port on the device.
 - Select Serial Port.
 - Edit the port parameters as required.
 - Select Apply.
Serial Port Field Descriptions
Use the data in the following table to use the Serial Port tab.
                                 Name  |
                                 Description  |
                                 IfIndex  |
                                 Identifies the port as a serial port.  |
                                 BaudRate  |
                                 Specifies the baud rate of this port. The default value is 115200.  |
                                 DataBits  |
                                 Specifies the number of data bits, for each byte of data, this port sends and receives. The default is eight.  |
