Modify an existing TACACS+ configuration to customize the server.
                                In the
                                        navigation pane, expand .
 - Click TACACS+.
 - Click TACACS+ Servers tab.
 - Double-click in the
fields that you want to modify.
In some of the fields, the text becomes bold, which indicates that you can edit them. In other
                                                fields, the system displays a list.
 - In the fields that
you can edit, type the desired values.
 - In the fields with
lists, select the desired option.
 - Click Apply.
