Use this procedure to configure the Fabric Attach assignment time-out.
Configure the FA assignment time-out:
Switch:1>en Switch:1#conf t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#fa assignment-timeout 50
Verify the configuration:
Switch:1(config)#show fa
                          Fabric Attach Configuration
                            FA Service : enabled
                       FA Element Type : server
                 FA Assignment Timeout : 50
                  FA Discovery Timeout : 240
                     FA Provision Mode : spbm
Variable definitions
The following table defines parameters for the fa assignment-timeout command.
 Variable  |
 Value  |
 <45–480>  |
 Specifies the Fabric Attach assignment time-out in seconds. The default value is 240 seconds.  |
