Use the following procedure to configure an IS-IS manual area.
 - Select IS-IS.
 - Select the Manual Area tab.
 - Select Insert.
 - In the AreaAddr field, type the Area Address.
 - Select Insert.
Manual Area or Manual Area Remote Field Descriptions
Use the data in the following table to use the Manual Area or Manual Area Remote tab.
                         Name  |
                         Description  |
                         AreaAddr  |
                         Specifies the IS-IS manual area. Valid value is 1-13 bytes in the format <xx.xxxx.xxxx...xxxx>. Only one manual area is supported. Use the same manual area across the entire SPBM cloud. For IS-IS to operate, you must configure at least one manual area.  |
