Configure IGMP sender entries to identify a source that sends multicast data to a multicast group.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
- In the navigation pane, expand the following folders: .
- Select IGMP.
- Select the Sender tab.
- Change the appropriate options.
- Select Apply.
Sender field descriptions
Use the data in the following table to use the Sender tab.
Name |
Description |
IfIndex |
Specifies the interface where you enabled the IGMP entry. |
GrpAddr |
Specifies the multicast group address of the multicast stream. Within the indicated valid range (224.0.0.0 to 239.255.255.255), the following are invalid addresses: 244.0.0.x and the corresponding 31 multicast addresses that map to the IP MAC addresses. If you try to select them, you receive an error message. |
MemberAddr |
Specifies the IP address of a host. |
Action |
Flushes an entry or a group. |
TPort |
Identifies the T port. |
State |
Indicates whether a sender exists because of an IGMP access filter. The options are filtered and not filtered. |
L2Isid |
Specifies the Layer 2 I-SID of the C-VLAN. |
ScopeIsid |
Indicates the scope I-SID of SPB routed multicast sender. If the sender does not support an SPB scope I-SID, the field displays an invalid value of 0xFFFFFFFF. |
DataIsid |
Indicates the data I-SID of SPB routed multicast sender. If the sender does not support an SPB data I-SID, the field displays an invalid value of 0xFFFFFFFF. |
