Use the following procedure to display the SPB-PIM Gateway neighbor information
 - Click SPB-PIM-GW.
 - Click the Neighbors tab.
Neighbors field descriptions
Use the data in the following table to use the Neighbors tab.
 Name  |
 Description  |
 IfIndex  |
 Specifies the IfIndex for the interface which is used to reach this SPB-PIM Gateway neighbor.  |
 AddressType  |
 Specifies the address type of this SPB-PIM Gateway neighbor.  |
 Address  |
 Specifies the primary IP address of this router on this SPB-PIM Gateway neighbor.  |
 UpTime  |
 Specifies the time since this SPB-PIM Gateway neighbor last became a neighbor of the local router.  |
 ExpiryTime  |
 Specifies the minimum time remaining before this SPB-PIM Gateway neighbor times out.  |
