Configure Global DNS
Use this procedure to configure the DHCP Server Global DNS tab in
EDM.
- In the navigation pane, select .
- Select the Global DNS tab.
- In the IP address field, enter an IPv4 address for the DNS server.
- Select Insert.
- Repeat these steps if you want to add additional servers.
Global DNS Field Descriptions
Use the data in the following table to configure the Global DNS tab for DHCP Server.
| Name | Description |
| IP Address | Specifies the IPv4 address of the DNS server. You can enter a maximum of eight DNS servers. |
