Perform this procedure to configure the remote hello multiplier to specify how many hellos the switch must miss before it considers the adjacency with a neighboring switch down.
Configuring the remote hello multiplier on port 1/2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#isis remote l1-hello-multiplier 1
The following table defines parameters for the isis remote l1-hello-multiplier command.
| Variable | Value |
| <1-600> |
                                 Configures the Level 1 hello multiplier. The default value is 3 seconds.  |
