Configure the Spanning Tree mode to change the mode to MSTP or RSTP mode.
Important
After you change the mode, restart the system for the changes to take effect.
Globals field descriptions
Use the data in the following table to use the Globals tab.
 Name  |
 Description  |
 SpanningTreeAdminMode  |
 Configures the spanning tree mode as either RSTP or MSTP. The default is MSTP.  |
 SpanningTreeOperMode  |
 Specifies the current mode of the spanning tree.  |
