Configure mesh groups to reduce SA flooding. A mesh group does not forward SA messages to other group members in the same mesh group. The originator, which is also a mesh group member, forwards SA messages to all group members. Create MSDP mesh groups from a group of meshed MSDP speakers from a domain. Do not create MSDP peerings between Controllers within the same SPB domain.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
 - Select MSDP.
 - Select the Mesh Group tab.
 - Select Insert.
 - In Name, type a name for the mesh group.
 - In PeerAddress, type the IP address of the peer to add the mesh group.
 - Select Insert.
Mesh Group field descriptions
Use the data in the following table to use the Mesh Group tab.
 Name  |
 Description  |
 Name  |
 Specifies the mesh group ID; the name of the mesh group from 1-64 characters.  |
 PeerAddress  |
 Specifies the IP address of the MSDP router that is the peer.  |
