Configure the maximum header size on a single port or multiple ports.
You must globally enable sFlow.
For ports 1/1 to 1/10, configure the maximum header size, and then verify the configuration.
Switch:1(config-if)#interface gigabitethernet 1/1-1/10
Switch:1(config-if)#sflow max-header-size 255
Switch:1(config-if)#show sflow interface 1/1-1/10
                         sFlow Port Configuration Info
Port   Packet-Sample-Rate  Max-Header-Size Counter-interval  Collector-list
                                           (in secs)
1/1    0                   255             525               1,2
1/2    0                   255             525               1,2
1/3    0                   255             525               1,2
1/4    0                   255             525               1,2
1/5    0                   255             525               1,2
1/6    0                   255             525               1,2
1/7    0                   255             525               1,2
1/8    0                   255             525               1,2
1/9    0                   255             525               1,2
1/10   0                   255             525               1,2
Use the data in the following table to use the max-header-size command.
 Variable  |
 Value  |
 <64–256>  |
 Identifies the maximum number of bytes to be copied from the sampled packet. Default 128 bytes.  |
