View VRFs corresponding to Layer 3 (routed) VSN I-SIDs on either a Controller or a Leaf node.
Ensure that you enable DvR globally on the node.
View Layer 3 VSN information on a DvR Controller:
Switch:1#show dvr l3vsn
                         DVR L3VSN
VRF ID            L3VSN ISID    VRF NAME   INJECT-DEFAULT-ROUTE-DISABLE
1                 55500         vrf600     Disabled
2                 55501         vrf601     Disabled
3                 55502         vrf602     Disabled
4                 55503         vrf603     Disabled
4 out of 4 Total Num of DVR L3VSN displayed
View Layer 3 VSN information on a DvR Leaf node:
Switch2:1#show dvr l3vsn
                         DVR L3VSN
1                 55500         vrf600
2                 55501         vrf601
3                 55502         vrf602
3 out of 3 Total Num of DVR L3VSN displayed
Variable definitions
Use the data in the following table to use the show dvr l3vsn command.
 Variable  |
 Value  |
 l3isid <0-16777215>  |
 Specifies the Layer 3 VSN I-SID. The range is 0 to 16777215.  |
 vrf WORD<1-16>  |
 Specifies the VRF name of the VRF corresponding to the Layer 3 VSN I-SID.  |
 vrfids WORD<0-512>  |
 Specifies the VRF ID of the VRF.  |
