Perform this procedure to verify that the software files are downloaded properly to the switch. The MD5 checksum for each release is available on the Extreme Networks Support website.
Download the MD5 checksum to an intermediate workstation or server where you can open and view the contents.
Download the image file to the switch.
Calculate and verify the MD5 checksum after you download software files.
View the contents of the MD5 checksum on the workstation or server:
183eacd80a1571fc8d15676a3c9366bb FabricIPSecGW_VM_5.2.0.0.ova eb86e5991d8ce2a69b21510b993e0727 restconf_yang.tgz adc1468688e8484d0b40443c39f14e51 TPVM_Ubuntu20.04_04_14Apr2022.qcow2 aeeeff32dd58708237bbc6fb905c66e6 VOSS4900.8.10.0.0_edoc.tar 6fa2e4a2a701b4481446828191d55749 VOSS4900.8.10.0.0_mib_sup.txt 45d5ab27b6bf685c086c5a4ce1b47576 VOSS4900.8.10.0.0_mib.txt 4d71d0b020cb75a6ebb54d91cd62c445 VOSS4900.8.10.0.0_mib.zip 0ebd29b5fca139c0afb1585b1933b3a8 VOSS4900.8.10.0.0_oss-notice.html a71ebe5a0c1c2d2a5056ddaca0124aef VOSS4900.8.10.0.0.tgz bb4d40f59ed40f56a47f657821b9b35d VOSSv8.10.0_HELP_EDM_gzip.zip
Calculate the MD5 checksum for the file on the switch:
Switch:1>ls *.tgz Listing Directory /intflash: -rw-r--r-- 1 0 0 322724024 Jun 5 16:25 VOSS4900.8.10.0.0.tgz Switch:1>file-checksum md5 VOSS4900.8.10.0.0.tgz MD5 (VOSS4900.8.10.0.0.tgz) = a71ebe5a0c1c2d2a5056ddaca0124aef
The following table defines parameters for the file-checksum md5 command:
Variable |
Value |
WORD<1-99> |
Specifies the file name. |
