Table 1. Link Debounce for WAN Links
Feature
Product
Release introduced
5320 Series
Fabric Engine 8.6
5420 Series
VOSS 8.5
5520 Series
VOSS 8.5
5720 Series
Fabric Engine 8.7
7520 Series
Fabric Engine 8.10
7720 Series
Fabric Engine 8.10
VSP 4900 Series
VOSS 8.4.2
VSP 7400 Series
VOSS 8.4.2
In a WAN environment, when a carrier-side link failure occurs, switchover on the carrier side can take a few hundred milliseconds. During that time, a lag in the sending and receiving of packets can occur. Use Link Debounce to hold the connection path until the switchover is complete. You can configure Link Debounce on each port.
Link Debounce protects the upper layers from unnecessary state changes by delaying the change of a port link state when the following situations occur:
Link Debounce works only on Layer 1 protocol applications. Layer 2 / Layer 3 protocols make decisions based on how they receive packets. For example, STP makes the decision according to the lack of traffic and port up condition; OSPF and IS-IS can still fail adjacencies.
You cannot configure Link Debounce on Integrated Application Hosting (IAH ) ports (also known as Insight ports).
