Configure the logon banner to display a message to users before authentication and configure a system login message-of-the-day in the form of a text banner that displays after each successful logon.
You can use the custom logon banner to display company information, such as company name and contact information. For security, you can change the default logon banner of the switch, which contains specific system information, including platform type and software release.
Use the custom message-of-the-day to update users on a configuration change, a system update or maintenance schedule. For security purposes, you can also create a message-of-the-day with a warning message to users that, “Unauthorized access to the system is forbidden.”
Configure the custom banner to “Company, www.Companyname.com.” and configure the message of the day to “Unauthorized access to this system is forbidden. Please logout now.”
Switch:1> enable
Switch:1#configure terminal
Switch:1(config)# banner custom
Switch:1(config)# banner Company
Switch:1(config)# banner www.Companyname.com
Switch:1(config)# banner motd "Unauthorized access to this system is forbidden"
Switch:1(config)# banner motd "Please logout now"
Switch:1(config)#banner displaymotd
Switch:1(config)#show banner
Company
www.company.com
               defaultbanner : false
               custom banner :
                 displaymotd : true
                 custom motd :
Please logout now
Variable definitions
Use the data in the following table to use the banner command.
 Variable  |
 Value  |
 custom  |
 Disables the use of the default banner.  |
 static  |
 Activates the use of the default banner.  |
 WORD <1–80>  |
 Adds lines of text to the CLI logon banner.  |
 motd WORD<1–1516>  |
 Create the message of the day. To provide a string with spaces, include the text in quotation marks (“).  |
 displaymotd  |
 Enable the custom message of the day.  |
