You can view status statistics for Rapid Spanning Tree Protocol (RSTP).
 - Click RSTP.
 - In the RSTP Status tab, select a port, and then click Graph.
RSTP Status Field Descriptions
The following table describes the RSTP Status fields.
 Name  |
 Description  |
 RxRstBpduCount  |
 Specifies the number of RSTP BPDUs this port received.  |
 RxConfigBpduCount  |
 Specifies the number of configuration BPDUs this port received.  |
 RxTcnBpduCount  |
 Specifies the number of TCN BPDUs this port received.  |
 TxRstBpduCount  |
 Specifies the number of RSTP BPDUs this port transmitted.  |
 TxConfigBpduCount  |
 Specifies the number of Config BPDUs this port transmitted.  |
 TxTcnBpduCount  |
 Specifies the number of TCN BPDUs this port transmitted.  |
 InvalidRstBpduRxCount  |
 Specifies the number of invalid RSTP BPDUs this port received. A trap is generated on the occurrence of this event.  |
 InvalidConfigBpduRx Count  |
 Specifies the number of invalid configuration BPDUs this port received. A trap is generated on the occurrence of this event.  |
 InvalidTcnBpduRxCount  |
 Specifies the number of invalid TCN BPDUs this port received. A trap is generated on the occurrence of this event.  |
 ProtocolMigrationCount  |
 Specifies the number of times this port migrated from one STP protocol version to another. The relevant protocols are STP-Compatible and RSTP. A trap is generated on the occurrence of this event.  |
