Enable SSH Rekey
You cannot enable SSH rekey selectively for the SSH client, SSH server, Secure Copy (SCP), or Secure File Transfer Protocol (SFTP); SSH rekey is enabled for all of these functions simultaneously.
Enable SSH globally.
The following table defines parameters for the ssh rekey command.
 Variable  |
 Value  |
 enable  |
 Enables SSH rekey globally. The default is disabled.  |
