Use the following procedure to enable ARP on VLAN level.
ARP field descriptions
Use the data in the following table to use the ARP tab.
 Name  |
 Description  |
 DoProxy  |
 Configures the system to respond to an ARP request from a locally attached host or end station for a remote destination. The default value is disable.  |
 DoResp  |
 Configures the system to send ARP responses for this IP interface address. The default value is enable.  |
