Configuring CFM MEP
Use this procedure to configure the CFM Maintenance Endpoint (MEP). A MEP represents a managed CFM entity, associated with a specific Domain Service Access Point (DoSAP) of a service instance, which can generate and receive CFM Protocol Data Units (PDU) and track any responses. A MEP is created by MEP ID under the context of an MA.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# cfm maintenance-endpoint md1 ma1 1 state enable
Switch:1(config)# show cfm maintenance-endpoint
                         Maintenance Endpoint Config
DOMAIN                 ASSOCIATION            MEP  ADMIN
NAME                   NAME                   ID
md1                    ma1                    1    enable
 Total number of MEP entries: 1.
                         Maintenance Endpoint Service
DOMAIN_NAME            ASSN_NAME              MEP_ID TYPE    SERVICE_DESCRIPTION
md1                    ma1                    1      nodal   Vlan 1, Level 4
The following table defines parameters for the cfm maintenance-endpoint command.
 Variable  |
 Value  |
 WORD<0–22>  |
 The first parameter, specifies the MD name.  |
 WORD<0–22>  |
 The second parameter, specifies the MA short name.  |
 <1–8191>  |
 Specifies the MEP ID.  |
 enable  |
 Enables an existing MEP. Use this parameter with the no option to disable an existing MEP.  |
 state {enable | disable}  |
 Enables or disables the MEP when creating the MEP. The default is disabled.  |
