Perform the following procedure to view the number of remaining virtual services resources on the switch.
 - Click Virtual Service.
 - Click the Globals tab.
Use data in the following table to use the Globals tab.
                                                 Name  |
                                                 Description  |
                                                 DiskRemain  |
                                                 Shows the remaining disk space available, in Gigabytes (GB).  |
                                                 NumCoresRemain  |
                                                 Shows the remaining number of CPU cores available.  |
                                                 MemSizeRemain  |
                                                 Shows the remaining amount of memory size available, in Megabytes (MB).  |
                                                   CopySourceFile  |
                                                   Specifies the source file to copy. To specify a location, use the format: {VM_NAME_SRC}:{VM_FILE_PATH} or {NOS_FILE_PATH}. For example, figw:/home/rwa/configs/ipsec1.cfg identifies a file located in the VM. /intflash/ipsec1.cfg identifies a file located in the NOS. The valid path for a NOS location can be one of the following:
                                                   CopyDestinationFile  |
                                                   Specifies the destination file to copy. To specify a location, use the format: {VM_NAME_DST}:{VM_FILE_PATH} or {NOS_FILE_PATH}. For example, figw:/home/rwa/configs/ipsec1.cfg identifies a file located in the VM. /intflash/ipsec1.cfg identifies a file located in the NOS. The valid path for a NOS location can be one of the following:
                                                   CopyAction  |
                                                   Specifies an action to copy a file from source to destination. The switch supports the following action:
                                                   ScalarsName  |
                                                   Specifies the virtual service name. You must specify the virtual service name if you use this tab to change the password or run a command.  |
                                                   ExecuteCommand  |
                                                   Specifies the Virtual Machine (VM) command to run. To include spaces in the syntax, include the text string in quotation marks (").  |
                                                   User  |
                                                   Specifies the virtual service user name. The range is 0-20 characters.  |
                                                   Password  |
                                                   Specifies the virtual service password.  |
                                                   FigwCli  |
                                                   Specifies the command to send to the Fabric IPsec Gateway VM. For more information about Fabric IPsec Gateway commands, see VOSS CLI Commands Reference.  |
