The Extreme-Dynamic-Client-Assignments Vendor Specific Attribute (VSA) is a RADIUS VSA for dynamic VLAN and Private VLAN (PVLAN) creation. You can also configure VLAN parameters, such as VLAN name, I-SID to VLAN association, I-SID name, and I-SID to dynamic VRF association.
You can use Extreme-Dynamic-Config RADIUS VSA to configure the VLAN-based features.
Platform VLAN manual
                            configuration—This maps the Extreme-Dynamic-Client-Assignments
                        Radius VSA without create. Only the options used to define the existing
                        functionality of mapping clients to VLAN on regular ports or vlan:isid on
                        flex-uni ports are used—Primary VLAN (PV), Virtual Network Identifier (VNI),
                        and Egress VLAN (EV). The Secondary VLAN (SV), VLAN Name (VN), and VNIN
                        attributes for dynamic VLAN are ignored.
Regular VLAN
                            configuration—This maps the VSA with the option create=vlan. The
                        Multiple Spanning Tree Protocol (MSTP) instance is 0. When platform VLAN is
                        dynamically created, all VLAN parameters are also dynamically applied; a
                        static VLAN setting is not allowed. Dynamic platform VLANs and dynamic
                        I-SIDs names exist as long as EAP clients reference them. If clients do not
                        use them, then they are deleted and are not saved in the configuration file.
PVLAN
                        configuration—This maps with the usage of
                        Extreme-Dynamic-Client-Assignments Radius VSA with the create=pvlan
                        option. The EAP and Private VLANs on regular ports are not supported. But
                        they are supported on flex-uni ports. The MSTP instance is 0. When you
                        dynamically create a private VLAN, all VLAN parameters are also dynamically
                        created; this is no static setting allowed. Dynamic PVLANs and dynamic
Use the information in the following tables and this string format to create a dynamic VLAN:
create=vlan|pvlan,pv=Primary
                VLANID, sv=secondary VLANID, vni=ISID, ev=EGRESS-VLAN-tag, vn=vlan-name,
                vnin=isid-name, mvni=ISID
If ev is missing, it
                will default to 0.
                You can also use U
                or T
                (case-sensitive). When ev is set to U, it is untagged or
                    0. When
                    ev is set to T, it takes the value of
                    pv or tagged. If
                    pv is not
                specified, then an error occurs and the VSA is ignored.
| Option | Description |
create=vlan |
                                pvlan
                             If  Note the following two examples:
 This option is ignored on DvR Leafs.  |
                            pv=Primary VLANID
                             The platform VLAN that the client is assigned. This option is valid for any combination of the   |
sv=Secondary
                                VLANID  |
                             This option is only valid for a private VLAN and if the   |
vni=ISID
                             If you did not use  The   |
                            ev=EGRESS-VLAN-tag
                             Use this option on regular ports to tag or untag the egress for the PV. Use this option on flex-uni ports as   |
                            vn=Vlan name
                             Valid only if you use   |
                            vnin=ISID name
mvni=ISID |
                             Use this option to configure IP Multicast config-lite for Fabric Connect functionality. This option configures the I-SID value for the Layer 3 VSN VLAN and enables SPB Multicast on the VLAN. For information about IP Multicast config-lite for Fabric Connect, see IP Multicast config-lite for Fabric Connect.  |
| Port Type | RADIUS Attribute | Extreme-Dynamic-Client-Assignments Radius VSA | Comment |
                             Regular port  |
                             Tunnel Private GroupID  |
                             Without
                             This adds the port to the primary VLAN; tag is the port tag.  |
                             Without
                             Untagged:  Tagged:  This adds the port to the primary VLAN; The VLAN egress tag is
                                dictated by the   |
                             Not Supported  |
                             Flex-Uni ports  |
                        Without create.
                             Untagged:  Tagged:  A S-UNI is created, either MAC-based or regular, depending on
                                MHMV/MHSA setting; uses   |
                             Supported by the same combination for FA VLAN:ISID  |
                        Without create.
                                MHMV/MHSA setting; uses auto configured   |
                             Not supported  |
                             Not supported  |
The dynamic VLAN is deleted after you disconnect all of the clients across the Extensible Authentication Protocol (EAP) ports. The port is removed when the last client is disconnected and the saved I-SID name is restored.
You cannot delete a static VLAN if EAP ports are assigned to it. However, you can delete the VLAN if you have added EAP FlexUNI ports to it. This flushes all MAC addresses and deletes any Non-EAP (NEAP) sessions. The MAC address is re-learned in I-SID and a new RADIUS authentication can now create a dynamic VLAN. For EAP sessions, the session moves to the re-authentication state, and the new RADIUS authentication can create a dynamic VLAN.
In Multiple Host Multiple VLAN (MHMV), if there are multiple assignments received for one session, the rule is to process only the last one and ignore the rest.
