Use this procedure to display information about RADIUS CoA statistics.
 - Click RADIUS CoA.
 - Click the CoA Stats tab.
CoA Stats Field Descriptions
Use the data in the following table to use the CoA Stats tab.
 Name  |
 Description  |
 AddressType  |
 Specifies the RADIUS Dynamic Authorization Client IP address type.  |
 Address  |
 Specifies the RADIUS Dynamic Authorization Client IP address.  |
 DisconRequests  |
 Specifies the number of RADIUS Disconnect-Requests received from this Dynamic Authorization Client. This also includes the Disconnect requests that have a Service-Type attribute with a value of Authorize Only.  |
 DisconAuthOnlyRequests  |
 Specifies the number of RADIUS Disconnect-Requests that include a Service-Type attribute with value Authorize Only received from this Dynamic Authorization Client.  |
 DupDisconRequests  |
 Specifies the number of duplicate RADIUS Disconnect-Request packets received from this Dynamic Authorization Client.  |
 DisconAcks  |
 Specifies the number of RADIUS Disconnect-ACK packets sent to this Dynamic Authorization Client.  |
 DisconNaks  |
 Specifies the number of RADIUS Disconnect-ACK packets sent to this Dynamic Authorization Client. This includes the RADIUS Disconnect-ACK packets sent with a Service-Type attribute value of Authorize Only, and the RADIUS Disconnect-ACK packets sent because no session context was found.  |
 DisconNakAuthOnlyRequests  |
 Specifies the number of RADIUS Disconnect-NAK packets that include a Service-Type attribute with a value of Authorize Only sent to this Dynamic Authorization Client.  |
 DisconNakSessNoContext  |
 Specifies the number of RADIUS Disconnect-NAK packets sent to this Dynamic Authorization Client because no session context was found.  |
 DisconUserSessRemoved  |
 Specifies the number of user sessions removed for the Disconnect-Requests received from this Dynamic Authorization Client. Depending on site-specific policies, a single Disconnect-Request can change the authorization of multiple user sessions. In cases where the Dynamic Authorization Server has no knowledge of the number of user sessions that are affected by a single request, each Disconnect-Request counts as a single affected user session.  |
 MalformedDisconRequests  |
 Specifies the number of malformed RADIUS Disconnect-Request packets received from the Dynamic Authorization Client. Bad authenticators and unknown types are not included as malformed Disconnect-Requests.  |
 UnknownTypes  |
 Specifies the number of incoming requests that have an invalid ID type.  |
