Use the following procedure to enable MLD snooping on the switch.
- In the navigation pane, expand the following folders: .
 - Click IPv6 MLD.
 - Click Snooping tab.
 - Select a value, double-click the cell in SnoopEnable column, select True or False.
 - Select a value, double-click the cell in SsmEnable column, select True or False.
 - Click Apply.
Snooping field description
Use the data in the following table to use the Snooping tab.
 Field  |
 Description  |
 IfIndex  |
 Specifies the interface on which you enabled MLD snooping. It specifies the port number if the interface is a brouter port or the VLAN number if the interface is a VLAN.  |
 SnoopEnable  |
 Indicates the status of MLD snooping on the specified interface:
 SsmEnable  |
 Indicates the status of SSM on the specified interface:
