Each PoE port has a configurable power limit. This configuration attribute limits the amount of power supplied on a particular port and varies across different hardware platforms. If a PD requires more than the configured limit, the device will not connect properly or is forced to run at a lower limit.
The following table lists the power limit for different hardware platforms:
               Platform  |
               Power Limit  |
               VSP4900-48P  |
               32 watts  |
               VSP4900-12MXU-12XE  |
               64 watts  |
