Use this procedure to view or modify configuration information about the DHCP relay on IP interfaces.
- In the navigation tree, expand .
 - Select DHCP Relay.
 - Select the Interfaces tab.
 - To change the configuration information, select the field in the row for the required interface, and then type or select a new value.
 - Select Apply.
Interfaces Field Descriptions
Use the data in the following table to use the Interfaces tab.
 Variable  |
 Value  |
 IfIndex  |
 Display a read-only interface number that represents a physical interface, or the VLAN logical interface.  |
 MaxHop  |
 Specifies the maximum number of hops a DHCP packet can take from the DHCP client to the DHCP server. The default is 4.  |
 MinSec  |
 Specifies the minimum number of seconds to wait between receiving a DHCP packet and forwarding the DHCP packet to the DHCP server. A value of 0 indicates that forwarding is done immediately. The default value is 0.  |
 Mode  |
 Specifies the type of DHCP packet required. The options are:
 The default is both.  |
 AlwaysBroadcast  |
 Specifies if DHCP Reply packets can be sent as a broadcast to the DHCP client. The default is false.  |
 CircuitId  |
 Specifies whether DHCP Relay inserts the option 82 circuit ID information into the DHCP packets before sending the DHCP packets to the DHCP server. The default is false.  |
 RemoteId  |
 Specifies whether DHCP Relay inserts the option 82 remote ID information into the DHCP packets before sending the DHCP packets to the DHCP server. The default is false.  |
 Trusted  |
 Specifies if DHCP packets come through a trusted DHCP circuit. Only packets with GIADDR configured to 0 and containing option 82 are forwarded if the circuit is trusted. The default value is false.  |
                                 SmartRelayMode  |
                                 Enables DHCP Smart Relay on a VLAN interface in one of the following modes:
 By default, Smart Relay is disabled.  |
