Perform this procedure to configure remote IS-IS global parameters. SPBM uses IS-IS to discover network topology, build shortest path trees between network nodes, and communicate network information in the control plane.
 - Select IS-IS Remote.
 - Select the Globals tab.
 - Configure the remote IS-IS global parameters.
 - Click Apply.
Use the data in the following table to use the Globals tab.
                                 Name  |
                                 Description  |
                                 AdminState  |
                                 Specifies the global status of remote IS-IS on the switch. The default is off.  |
                                 SystemId  |
                                 Specifies the IS-IS system ID for the switch. Valid value is a 6–byte value in the format <xxxx.xxxx.xxxx>. Important:
                            After you configure the SPBM nickname and enable remote IS-IS, if you change the system ID, you must also change the nickname. However, changing the nickname could impact the naming convention or configuration. To maintain the same nickname with a different system ID, see Job aid.  |
                                 DynamicallyLearnedArea  |
                                 For FAN members, specifies the remote IS-IS area that is dynamically learned from the neighbor‘s Hello PDU if the node does not have the IS-IS manual area configured.  |
                                 MAOperState  |
                            Specifies the Multi-area SPB operational state:
| MAFlags |
                                 Specifies the Multi-area SPB as a boundary node to forward traffic from the UNIs to the remote-area and from the remote-area to the UNIs without requiring an established adjacency in the home area. The default is disabled.  |
